John Deere 730 diesel fuel in oil
Beefyjd
New User
Hi all, with the fuel on and sitting, not running im getting fuel in oil. Turn the sediment bowl off, the level doesnt rise. Could it be the check valve coming out the cover over the pumps? Thanks again guys and gals.[/img]
Underneath the fuel rack there is a short stand pipe between the block and the rack. There is an o-ring on each end of this pipe they get hard and leak. There are 2 gaskets that go underneath each end of the rack that you will need also.
