3010 Rear Axle Greasing
vapet
Replacing fenders on 3010 utility that I've had 4 or 5 years. Never could get the plugs out to install zerks so that required removing the fender brackets. Anyway I have no idea when was the last time the bearings where greased, if ever. Manual gives an amount, but that would be for tractor that is serviced regularly. Suggestions on how much?
Id start with the recommended squirts.. I have plugs in mine that I have to remove and put in zerk when I grease then remove put plug back in.. dont know why they didnt have zerks nor why I have never just bought two and left in..
To much is worse than not enough. Over grease them and you will be pulling the axle to replace the seal. The only time I ever seen those bearings fail was on a tractor that spent lots of hours under a mounted corn picker.Most have never been greased and will never cause a problem. Tom
