I have a JD 40. Everything was fine, started and ran out fine, good oil pressure. Then:
*antifreeze began appearing in oil, and discolored it
* antifreeze level in radiator dropping
*NO LEAKS on the floor
Tractor ran out fine from the beginning, but when it smelled hot, I discovered the above. I changed out the oil, filter, topped off antifreeze....and it's doing the same thing.
Is there any way to get to the problem so I can fix it? What is actually happening?
Thanks, I've worked on a lot of JD's, this is a new one.
