John Deere b clutch driver
78camaro
New User
Anyone know of a good tractor salvage yards in Michigan I
need a good clutch driver but I don?t want to buy a new one if I
don?t have too or does anyone know where I can get a decent
parts tractor mine is a 1945 John Deere b thanks for any help
You are aware that IF your old clutch-driver was Loose on the crankshaft splines, you will most likely need an "Under-sized" clutch driver..
That baby HAS to fit Tight with the crankshaft splines..any "Play" at all and both the driver and the crank can be ruined in a very short time..
FWIW...
I fixed mine with JB Weld. Just clean the splines real good with brake clean then smear some JB Weld on the driver spline and on the crank spline. Not too much so it makes a big mess. Then push the driver on and put the nut on and tighten it up. I put a light bulb close to mine for a day to help with hardening. Did it a couple years ago and its still tight.
