Pleasant Green Surprise
David G
I will probably redo the LI axle using thrust bearings from a 420, I want to use all the 420 components if so. I got the thrust bearings from this site, but needed the seal and seal retainer. They were $5 per site at JD, did not think they had anything for a buck anymore.
At least they had them, you will spend more than that in gas trying to find anything else, and your time?
