I have been restoring a 51 JD B. I just took it out for a test drive and everything seemed to work fine except for a few minor adjustments. My problem though is that I have a front tire wobble? It didn't do it before I started restoring it. I see a little play in the steering worm gear and the bushing. Would this be the cause and if so, how do I fix this problem. I don't believe its any worn bushing because, As I mentioned earlier, I don't remember having this problem before restoration.
Any help would be greatly appreciated.
Thanks
Jeff
Thanks
Jeff
