3020 hydraulics,, ? turn on for remote
trak
I'm tryin to use a remote cycl. what do I turn on or off? I got pioneer male couplers on the hyd. hoses,,, seems like the 3pt control needs to be all the way down? then the other control is supposed to run the remote? I've used the 3pt.. with forks on heavy stuff alright.. although it seems real jumpy comin up at idle speeds with no attatchments...
ok,, I put a cyclinder on for a brush hog,, don't seem to be getting any hyd. pressure into the hoses
Make sure you have hoses in completely and the lever at bottom locked in sideways position if it is an older 64/68 3020.It could be converted to pioneer ends which has same procedure.Make sure your hyd oil is at proper level.Possible to have filter needing changed but 3pt works with scvs at same time.JD ends are different than pioneer.When hooking up hyd hose make sure the center portion of scv is all the way back as some can stick and need a little tap with rubber hammer. If you can post a picture would help as a couple things in your question are confusing.
