randy 2240
New User
My 2240 a 1979 by serial # water pump went out. Per James River its not available anymore. I ordered one off here by serial # bolt pattern same but my original has 1 cooling point out top goint to top of thermostat housing. The new one has 2 lines out the bottom and 1 on top. Help How do I fis this the ports dont look like I can remove and plug...
Thanks for all yalls help!
Randy
pump is rebuild able. get you dealer to get you a rebuild kit and have them press it apart and
reassemble it, should not be more than 1 hour shop time
Those pipes are for an oil cooler. Just stick a heater hose
from one to the other.
James River/Wakefield rebuilt my 2510 water pump... no problem and it was reasonably priced.They pressed it back together while I waited, if I remember correctly.
