jdcolumbus
Still having issues getting gen light to work as it should. Tractor was previously wired as pictured with "s" terminal connected to the "B" terminal with the short red jumper wire.....alternator was charging but light not working. Per prior input from this site, we hooked the "G" which we thought wound be the same as the #1 terminal to the gen light. Light did not light with key on despite having power to it.
We then hooked "S" terminal to the key switch and "G" to gen light.....same results. We then switched wires so "s" was go to gen light. Light would then light with key on (progress huh!!), but would not go out when tractor started. In addition, alternator was not charging with this set up. Looking for suggestions on getting to gen light to work and alternator to charge as well. This John Deere reman alternator is different than the previously discussed Declo alternators with numbered terminals. Just trying to get the little dash light to work!!
