The steering on my JD 2030 is giving me fits! When I turn the wheel it vibrates/groans buzzes. It also hops up a little bit when it hits the right spot.
Also it has hydraulic oil leaking out through the access plate beside the brake pedals. When I pulled the plate oil gushed out. Is that compartment supposed to be filled to lube the parts?
Is this steering valve a good candidate for a rebuild or should I just start with a new one?
Thanks in advance!
Thanks in advance!
