susandiane
Here awhile back I had a leak in the bowl gasket of my 70 all fuel when it was on a hillside. Part of it was pouched out on the exhaust side of the tractor. Replaced it with a JD sourced gasket and forgot about it, until recently.
The last time I had it out, about 1 1/2 months ago, it began running poorly, like one cylinder wasn't all there. I was checking the plug wires and noticed puffs of vapor popping out of the region where the gasket was bad before. Not continuously but every 2-4 firing cycles. I checked level in carb with clear tubing/barbed fitting and it was fine. Things came up and I haven't gotten back to it.
Any ideas on what could be going on here?
Thanx!
Thanx!
