John Deere 620 Flywheel End Play
DanH
Having some issues with setting the flywheel end play on my JD 620. Took it apart to replace the broken inner thrust washer on the flywheel side. Didn?t check end play before I took it apart didn?t have a dial indicator. Put everything back together and following the the manual on setting the end play and I?m getting .040 thousands instead of the .005-.010. Any suggestions would be greatly appreciated.
Thanks Dan
