2630 wiring diagram needed
john *.?-!.* cub owner
I am trying to help a friend, he had told me it was a 2310, but I got a look at it in person today, and figured I would be ahead to start a new thread with the correct model.The tractor is in running condition, but most of the wiring has been cut off, or replaced with some very mickey mouse wiring that is not hooked up. Help in locating a diagram would be appreciated.
Thanks
You need to obtain a 2630 tech manual as it will have wiring diagram. You can order a TM from JD dealer or JD @ 800-522-7448
2nd question, the owner was not there and I could not find the brake lock if it has one. I did notice a pedal and lever at the rear of the left floorboard, but could not figure out their purpose, unless they had to do with a differential lock.
2630 has hydraulic brakes and no "brake lock".
There's a "Park" position in the transmission shifter.
I decided today that age and health had caught up with me to much to take on something this different from what I normally tinker with (70+ year old IH tractors), and told him he needed to get someone more familiar with these rigs than me to work on it. Steering needs rebuilt apparently, a lot of play in wheel and could see the sector ends of the tie rods moving up and down an inch or more as the steering wheel was turned back and forth.,
