This message is a reply to an archived post by Tim S on February 28, 2018 at 08:02:04.
The original subject was "Re: 4020 brake valve".
This is great info....I have a JD 4000 that I need to repair the break valve and replace the boots. Do you have a overhaul kit number for the JD 4000? and the part number for the boots? My boots are cracked and the valves are leaking also. I imagine the Kit for the 4020 would be the same.
