Transmission 51 A John Deere
Landon_wic18
New User
Driving it home yesterday hit a bump in the field. Acts like it knocks it out of 4th gear, I look and nothing has changed so I move it out of 4th and go right back in it, open clutch.. nothing.. same goes for 1,4,R if I pull the shift lever down past 4th(50-52 has square shift pattern) nothing will move won’t go into any other gear! Just need some help I’m confused!
You need to lift up the shift cover and put the shifters back in place. It sounds like the
overdrive shifter has moved.
How's your luck been running? You might be able to push down or pull up on the shifter and "fish around" and "catch something". The object is to get everything lined up in neutral. If it's not too
inconvenient or unsafe, jacking up a rear wheel and turning it a little bit one way or the other may "let you" get it into neutral. The ultimate solution is taking off shifter etc. It seems odd to my
ignorant mind that it would jump out hitting a bump. IMVHO it suggests that it wasn't fully "in". An very knowledgeable fellow suggested shifting to neutral while the clutch pulley is still moving but
almost to a stop, and never using any force to get it into gear. If it won't virtually "fall" in, roll the clutch pulley a bit until it will. Ever since I started calming down and getting the hurry out of
system and doing that, I've never had the problem again-yet. (Knock on wood eg, my head).
