70 Diesel fuel pump removal
I'm getting diesel fuel in the engine oil I took off the pump cover and there's fuel in the bottom of the pump compartment looks like it's coming from the gaskets where the pump bracket mounts to the cylinder block anything I should know to take that bracket out any help would be appreciated it leaks even when the tractor is sitting
Is it much of a problem to take that bracket out of there I don't know much about Diesel's would anything need to be retimed or just replace the seals around the injection pumps
