Too much radiator pressure
JLG
On a 730 diesel- it has so much pressure in
the radiator that its blowing water out.
It's NOT over heating, didn't even warm up
yet, and the oil is not milky. Sound like a
cracked head? And if so, why is the oil not
milky?
Thanks.
Quote:
On a 730 diesel- it has so much pressure in the radiator that its blowing water out. It's NOT over heating, didn't even warm up yet, and the oil is not milky. Sound like a cracked head? And if so, why is the oil not milky?
Neighbour had the SAME operating conditions on his JD 70 Diesel:
Removed the Main Engine HEAD....failed head Gasket:
Installed new head Gasket, new engine Thermostat (NOS), new temperature gauge, and re-torqued head after 2 hours of heavy working;
Neighbour would not have HEAD machined:
Followed instructions on Loctite 515 sealant:
515 sealant applied liberally to both sides of head gasket:
Bob..
Quote:On a 730 diesel- it has so much pressure in the radiator that its blowing water out. It's NOT over heating, didn't even warm up yet, and the oil is not milky. Sound like a cracked head? And if so, why is the oil not milky?
515 sealant applied to both sides of head gasket:
Bob..
