1936 unstyled B JD
I have nearly completed my restoration of this tractor. I am still looking for bolts to hold the rear wheel weights. Any idea where I might find some? I also need the shutters that go in front of the radiator.
final, in my dreams, I would like to find the pedestal and wide front axle for this tractor. Thanks, Mel
I don't think they came with shutters until 37. I think they had a grill guard with a curtain in 36. What kind of rims do you have?
My 1935 JD-B has shutter or should I say what is left of shutters. This tractor has ben part of my family since 1940 so either I have an odd ball of they could be had in 1935
Tractor has flat spoke wheels. I may just have to heat a bolt and bent a flat hook on it.
I agree on the shutter years, but my tractor had the lever to adjust louvers. With the roller, you had to get off the tractor to adjust it.
Thanks for the replys, Mel
My 1935 JD-B has the flat spoke wheels on it also but they are also steel wheels as in no tires. I do not recall ever seeing where wheel weights where offered on it either. I have the owners manual that came with the tractor when new but then on the other hand I played on that tractor some 55 plus years ago when my grand father owned it so I pretty much know what and where it was for decades
