John Deere 2940 SCV Rebuild
bonni100
New User
I have a 1981 John Deere 2940 that has 2 SCV that both allow fluid to bypass so when I hook up to an implement the cylinder either lowers or on my round baler lifts the latch cylinders. I would like to rebuild them or have them rebuilt. I bought the rebuild kits from JD but looking at the manual, I think I should probably send them somewhere to be rebuilt and tested. Any suggestions?
I can rebuild it here and bench test [email protected]
Welcome to YT
Tim is the person I'd send my JD closed center hyd components to for repair. I wish I had access to a hyd test bench such as he has built way back when I was a JD dealer service manager. I might not be a grey haired. :lol:
The SCV's can be repaired. Rebuilding them is not difficult for a JD tech that has been around them. Adjusting them takes a dial indicator, a service tool to hold valves shut and a little know how but, not hard if you understand what you are doing and can follow a tech manual. I rebuilt many of these in the last 40 years. Old and later versions. The later style box used on the 2840 are the easiest ones to do and takes a few hours. If you are in Eastern Iowa I could do them for you. DW
Thanks for the information. I will send it out. I couldn't find any places that rebuilt them, only purchase remanufactured parts online.
Hey,
As others have said here it's not difficult to repair them if you know what your doing and have the adjusting plate and a dial indicator. When I worked for a John Deere we did them all the time. We didn't have a bench tester but always had a tractor around we could stick it on and check it with two pressure gauges. If you don't have the right equipment, sending it out is the thing to do. Good Luck!
John
My method using air pressure eliminates the need for the special plate and dial indicator..I have been doing it this way for 30 years.
