2510 load control shaft job, continued
TXTN JD
I still haven't finished the load control shaft job on my 2510. Keep needing 'one more part'. I'm wondering now if I should replace the two bushings on each side the yoke. They don't seem worn, but if I slide the shaft through them, there is more wiggle than I expected. I guess it can't be too snug or else the shaft couldn't flex and do its job. Any opinions?
If I was replacing seals on a JD 2510 I'd acquire some Bolings Machine Shop bushing with groove inside to accommodate o-ring/quad ring type seals.
http://bolingmachine.com/
If you're that far into it put new ones in. You have to remove all the new seals, shims ,and oil to replace them if you do it later.
