I have a 1945 model "B". I have had this tractor for about 35years. I use it for hauling fire wood and working food plots and running a small bush hog. Yesterday I discovered that the manifold has a hole in it. Burned thru on the exhaust side facing the carb. Its the original hot manifold. I have a cold manifold and gas pistons from a parts tractor that I bought about 20 years ago. The pistons were stuck in the bore but after lots of soaking I got them out about 15 years ago. They have been sitting in the corner of the shed since then. Now that I am going to have to replace the manifold I'm thinking about installing the gas pistons also. I removed the rings and got the wrist pin out of one piston. I've heard of people reconditioning pistons and wonder if that is feasible or if I would be better off buying new pistons and rings. The gas pistons must be standard size as I don't see anything stamped on the top. I won't know if the block in my tractor is standard bore till I get it apart.
Thanks for any help or advice.
