2355 clutch slipping when warm?
Wblazzard
New User
Hello I?m new here but recently read of a similar issue that I?m having through this forum. I just purchased a JD 2355 and when it gets warm from pulling for an hour or so, it begins to act like clutch is slipping especially in higher gears. No smell of hot or slipping clutch though? Any ideas? Only 2300 hours
Welcome to YT
Does clutch foot pedal have any free travel? Does this tractor have hyd hi-lo or a hyd reverser? If so these have hyd clutches that could be slipping.
JD utility ""can not have both"" hyd hi-lo & hyd reverser only 1 or the other. I'd suggest to take some hyd pressure readings from ports on reverser shift valve located on RH side of clutch housing. One possibility is leaking oil supply tubes or seals.
