720 D Rear Wheels
MT RON
I have a dilemma with the rear wheels,the pinion adjusting bolts are missing on both wheels and I would like to move them.I haven't tried yet as they are loaded and not sure it would be possible.The pinions are still in both of them and I have a pinion bolt but don't know how to get it lined up as the pinions are way out of line.Has any one had this problem? Thanks for any response.Ron
Get a chain hoist, something that can lift upwards of 1 ton this is for safety . With Axel gear teeth on top ,Loosen the bolts on inside half, remove the outer half . Turn the wheel to bottom and gear should fall out . Replace the drive bolt and pinion . This is all assuming you have the wheel loosened .
Just remove the bottom wedge half and turn the wheel around working it to the position you want it then reassemble. Unless you plan on moving the wheels often I would not worry about even trying to free them up. Tom
