Making new LI axle
David G
If I am making new axle, should I look at putting thrust bearings in on bottom instead of washers?
I think the M might have used those.
If anyone needs to do this:
2 1/2 inch schedule 80 is perfect match for main tube, and 1 1/2 schedule 80 is perfect match for spindle tube.
This site has thrust bearings and spindle bushings for a 420 up, that is a 1.375 inch spindle, I will measure and see if LI has same diameter. They are pretty cheap here, and would save me a lot of time over punching out and reusing the old components. As suggested, I think bearings would turn lot easier than a thrust washer, and owner is a lady that is a few years older than I am.
The ID of the bushings are the same and the 420 and up, I am boring new holes so does not matter, but the OD is probably same too.
