I have two 1959 630 JDs. I have been trying to find out why the one with 80 hours on a complete engine overhaul (sleeved with new pistons, rings, rod bearings, valve job, manifolds, cam grind, and quite a few other parts has so much noise coming from the valve cover. I have adjusted the valves three times with a dial depth gauge and can't get them to quiet down. It sounds like valve noise but is quite a bit louder than the other 630 which has 180 hours on it since overhaul (not by me on the one, bought at auction). The noisy tractor does run great. My worst fear is a loose sleeve but the noise sounds like valve noise. I am using Mobil Delvac 15W-40 oil.
