Look what the guys at the store got their hands on
This wasn't there before. Looks like they've found the sleeve deck for a 1010 somewhere. Haven't ever seen it on here before....but man...$$$$$
http://www.yesterdaystractors.com/John-Deere-1010_Cylinder-Liner-Deck-Plate_AT12215.html
(quoted from post at 13:20:59 03/20/18) This wasn't there before. Looks like they've found the sleeve deck for a 1010 somewhere. Haven't ever seen it on here before....but man...$$$$$
$1501 for four sleeves. At that price you do not have the pistons! Sure that is expensive!
I read that the purpose of the sleeve and deck was that you could easily rebore it without having to take the motor out by splitting the tractor. It is quite ironic today that the overbore pistons are impossible to find and we can only find the expensive sleeves that were probably not really meant to be changed.
Over 10 years ago I looked for a sleeve set for a 1010 and the JD dealer said if he could get one which he was not sure of his old price sheet said $550. He also said if could get one it would be likely to be at least 25% more then what his sheet said
Old your dealer was way off even then. The sleeve deck has always been available. You did have to do some hoop jumping there for a while to follow the part number to the one JD was using at the time. The last one I sold was $1250 in 1998 or 1999.
(quoted from post at 20:22:46 03/20/18) If you're going to play with old stuff it costs $$$$.
Pony up or go home!
Well, In that size tractor, you could have bought a Massey 135 that you can get full rebuilt kit a crank and a cam for that price.
1500 dollars for four sleeves without pistons is outrageous.
I changed sleeves on a 5020 for $35 each. Factory direct...
