John deere 2120 Rear engine cover....
So, here's the rub. I have a 2120 that cracked the rear engine housing. 148 loader on it, I do not have the side supports.1. Does anyone have the actual part numbers for the Side mounts. Or is this something we just fab up. I've searched the site for this info but come up empty handed.
Key 1 is T21652
key 2 is T21651
This is amazing info, the new loader did not play well with the tractor. Bale spear broke shock loading the engine and BOOM. Oil everywhere.
I have a pair of used ones here if you are interested for $400 plus shipping. Reply back if interested but I will be leaving for a few days starting tonight. Tom
(reply to post at 18:08:49 03/14/18)
Okay, next question.
Which clutch will be on this unit? I look on parts list and I find that there is a few options. is there any way of knowing without actually holding the part.
IIRC it should be a 13 inch clutch, same for most open station 20 30 40 50 55 series
of that hp. But, you will have it out anyway, so just match it up then. Should be
able to get on in a day or two
Ben
(quoted from post at 03:53:31 03/15/18) IIRC it should be a 13 inch clutch, same for most open station 20 30 40 50 55 series
Ben
Alright, Was hoping to get at it and have it back together all in the same motion
