TractorLinks.com
Show Parts for Model:
Hydrolics
Rutroooo
03-13-2018 15:07:32
Changed out the fluid on a JD 310A because we saw water, was working just fine. Now it will not do anything, any suggestions
Rutroooo
03-13-2018 17:00:07
 Re: Hydrolics in reply to Rutroooo, 03-13-2018 15:07:32
Quoting Removed, click Modern View to seeThank you for the info and quick response.
Rutroooo
03-13-2018 16:56:36
Quoting Removed, click Modern View to seeThanks for the info and quick reply, hopefully it will be simple.
D-
03-13-2018 15:36:27
Sometimes the transmission pump won't pick up oil after oil is drained. Transmission pump has to be disassembled and reassembled using an anaerobic film. I can't remember the name but I think it's a Loctite product. Hopefully that won't be the problem.
Perhaps shifter cover could be removed and oil poured into the pump?
Tim S
03-13-2018 15:56:47
 Re: Hydrolics in reply to D-, 03-13-2018 15:36:27
That is wishful thinking ...;^)
Tim S
03-13-2018 15:24:41
Drain the oil and check the sump screen,,if you have a back hoe on it that can be difficult..if the screen is plugged strong chance the brakes went bad and the lining let loose,, also there is a cone shaped piece in the filter bowl that holds the filter in place,,some times that will stick to the old filter and it gets tossed with out realizing it,,so check for that too,,I hope that is in place,,bad things happen when it's missing..
