oil in M touch-o-matic
alfrehner
Hey all, just wondering what you use in your M touch o matic systems? The book says to use a 10W. Seems like I've used 10w-30 in the past, but just curious if anyone has
used hy gard with any luck. Thanks
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">just wondering what you use in your M touch o matic systems?[/i:654c4848f0][/b:654c4848f0]</font>"
We use 10W in our M Touch-O-Matic.
Like James non-detergent straight 10W or 20W depending on the season. The hydraulic pump on that tractor can leak back into the engine crankcase once the seals go bad. They do and will go bad. When that happens whatever is in the TOM can over time get into the crankcase. I am sure Hy-Gard would not hurt the system but I am not sure I personally would want that mixing into the engine oil.
