I picked up an MT back in January. Ran great and previous owner said he just had head work done on it. Been using it lightly on weekends. The last two weekends I've started it I get white smoke for a minute or two then it clears up and runs great. I noticed it slightly wet around where the head meets the block in a spot or two. Thinking it's the head gasket.
I want to try to re-torque the bolts before going any further. What torque setting should I use and should I do it hot or cold? Also, does the pattern matter since there is only four bolts?
Thank you for your help.
