John Deere 70/730
These are the gas versions. Top one is from a 70, bottom is 730.
Talking diesels here. 70 crank will work in a 720/730 but not a good idea to install a 720/730 crank in a 70. Centre bearing will not have pressure lubrication.
Information you may fined helpful...?
QUOTE:
Posted by kww900l on April 01, 2016 at 15:53:21
John Deere 70 diesel center main bearing
I recently acquired a 70 diesel that the crankshaft is broken at the flywheel on. I found a crankshaft and have seen posts about updating the center main bearing to a direct lube like the later 720 and was wondering if someone could tell me how to go about doing it
Pic's 1-2-3 are JD 70's:
Pics's 4-5-6 are JD 720's:
JD 70 SERVICE MANUAL:
SM-2017(1-56):
JD 720 SERVICE MANUAL:
SM-2020(12-57)
Bob...Retired Power Engineer....with NO experience in swapping JD "70" /"720"/730 Crankshafts...
