jd40203020
I am going to be istalling the head on my 1964 ( big injectors) 4020 diesel. I want some expert tips so I don't end up with annoying oil leaks near the right rear corner. Head has been plained and valves replaced.
Is it best to install the gasket dry, or should I use a spray on copper head gasket sealer? Should I re-use the old head bolts or buy new? What is the correct / newest torque procedure for the head bolts?
Thank you for your help as I only want to do this once!
