Sorry this is a long one guys. I noticed my JD 60 was running a bit rough today, like it sounded hollow or lean. Now I set the carb the way I wanted it two falls ago and haven't touched it since so I couldn't understand how it could be running too lean. I adjusted with the idle needles but that made no difference. I did the manifold a month ago but was careful especially where the intake was concerned that it wouldn't be sucking air. For the heck of it, I removed the spark plugs which had maybe 200 hours on them (autolite 3116). One looked fine. The other one had literally no gap--you couldn't even fit a piece of sandpaper between the electrode. Now this tractor ran great, idled well, started fine all last summer and fall plowing, raking, and shredding corn. It seems odd to me that I wouldn't have noticed it getting rougher. What might cause a once gapped plug to close on itself? The only thing I can think of is incorrect advance on the spark timing on the distributor or valves lash adjustment but I don't know whether that makes any sense and you certainly don't hear any noise on the valve train on this tractor. Thoughts?
Pete
Pete
