JD 2755 tachometer
cdv
just got a 2755 noticed the rpm s part works good but its not counting the hours stuck on 2956 is there a fix for this thanks cdv
Mine did that....check the contact points on the printed circuit behind the tach, they may just need a bit of cleaning.
Ben
The wiring connectors on the back of the printed circuit boards are notorious for having bad contacts. I had all kinds of problems with my wiring on my 2755, so I unsoldered the pins on the 12 pin (I think 12) plugs and soldered in new wires and ran them to GM Weatherpack connectors. Problem solved. The black rubber steering column dust shield is gone on my tractor, so it was easy to put pressure on the plugs and make things start working and stop working.
