4020 steering column leak
smcox1
New User
I have a 4020 and every time I fix one hydraulic leak another decides to show its ugly face. The current leak is coming out of in between two pieces and I don't know if there's a gasket in the middle or o ring that can be replaced or if the entire thing has to be rebuilt. And I mean it's just running out I leave a trail of hydraulic fluid everywhere I go lol! I'll post a picture of where the leak is coming from. Any help is greatly appreciated!!
There is an o-ring in that area,,you will need to have the valve re-sealed and re-calibrated..,, I can do that here for you if it's some thing that you can not do,,and bench test it to prove it..
I was hoping that wasn't the case :( If I have to pull it out I might as well just have it rebuilt because I rather not go through the process of removing it later on down the road for something else.
Not much of a way to partial Over haul it..it's all or none the way they are made..and they are a bit ornery to take out..
