What do you prefer
They are a pain..but o"rings and back-up rings do last longer and hold better on less than perfect barrels.
As far as couple tip seals..whatever Deere sells for the application...most old JD tip barrels require quads with back-up ring....
I don't use the quad seals that come in the kits,, I do use an actual quad ring and a solid back up ring, the seals I use are much better than anything out there now,, and the spiral back up rings can and will let the tail of the slip over and on top of the o-ring leaving a way for oil to leak past,, I use them on the barrels as well as the handles..
