4650 Light Problems
CDN 400
I just changed all the lights to led and the 2 inside fender lights will not go out on low beam. The outside work on both beams as they should. I don't know if they worked properly before I did this because the tractor is fairly new to me.
If you turn your light switch to the first light position after the flasher It should then have 1 bulb lit . Then on mine it shuts off the top half of the remaining 2 lights for low beam road travel or on high beam it lights the whole bulb Mine are Larsen Lights.
