Will the rear tires/wheels from a JD 50 bolt up to the cast rear wheels on a 1950 JD B?
And vice-versa will the 1950 rear tires/wheels bolt up to the JD 50? Both tractors have cast rear centers.
I know the rear rims are different, but can they be swapped between the two tractors?
The 50 is either a 1954 or 1955 model. Thanks. This ? Has probably been asked before, but I couldn't find the answer.
Thanks again for a response, MikeS.
