JD MT Starter
ratnester
Can a JD MT starter be removed without taking the battery box off? There is less than an inch clearance between it and the back of the starter. If so, I would guess it would need to be pulled off on the right side because of the sediment bowl, correct?
I need to get mine fixed and wanted to know if it's a five minute job or an hour since it's so cold.
No
It's an hour job, unless the 1/4" capscrews in the torque tube break off.
Take it off through either side of the tractor.
(reply to post at 17:19:06 02/15/18)
Just back the two 1/4" screws back then pull it back to remove? Don't see how that would take an hour, unless I'm missing something? I understand it would take a while if they broke of though.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Can a JD MT starter be removed without taking the battery box off?[/i:654c4848f0][/b:654c4848f0]</font>"
No.
You will need to remove the battery box.
a257080.jpg" width="650"
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">guess it would need to be pulled off on the right side[/i:654c4848f0][/b:654c4848f0]</font>"
Seems easier to me removing it from the right side.
Remove the battery cable and ammeter wire from the right side.
a257081.jpg" width="650"
Remove the hex jam nut and special set screw from the right side.
a257082.jpg" width="650"
a257083.jpg" width="650"
Remove the starting motor while on the right side.
a257085.jpg" width="650"
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">wanted to know if it's a five minute job or an hour[/i:654c4848f0][/b:654c4848f0]</font>"
It will take longer than 5 minutes, but it will take less than an hour with practice.
Hope this helps.
Thank you James! Exactly what I needed to know.
My apologies jCarroll, when you said No, I thought you meant I did not need to remove the battery box.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Just back the two 1/4" screws back then pull it back to remove?[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the [b:654c4848f0]BATTERY BOX ASSEMBLY[/b:654c4848f0] diagram below.
a257096.jpg" width="650"
Note the 1/4" cap screws (Key 1) and the 5/16" cap screws (Key 4).
Remove the two 5/16" cap screws and the battery tray (Key 22).
a257093.jpg" width="650"
Remove the two 5/16" cap screws in the tool box and battery shield assembly (Key 3).
Remove the six 1/4" cap screws then remove the tool box and battery shield assembly.
a257094.jpg" width="650"
Hope this helps.
I am with James. Been there, tried that, removed the battery. It is a good time to clean your battery connections, check for corrosion in the battery box or leaks, do any repairs behind the dash panel, etc.
