TractorLinks.com
Show Parts for Model:
John Deere 420 3-point creeps UP
DoubleO7
02-13-2018 17:21:44
The thread about a 520 3-point creeping down reminds me to ask:
When running my 420 with the pto driven woodchipper on the 3-point, I have to tie a rope on the single Touch-O-Matic.
To keep the chipper on the ground, otherwise it wants to rise in little jerks until it is up all the way.
Any ideas what to investigate?
jd2cylman
02-14-2018 15:07:07
 Re: John Deere 420 3-point creeps UP in reply to DoubleO7, 02-13-2018 17:21:44
I have a early 420U which also has just the single touch-o-matic.
I could see the friction disc being loose causing the lever to go down, but he said the lever creeps up. That has to be more due to a improperly set feedback spring like B&D suggest. Or possibly a leak in the lift valve circuit?
buickanddeere
02-14-2018 08:27:06
How much spring pressure is there on the top link feedback ?
James Howell
02-14-2018 06:56:26
"I have to tie a rope on the single Touch-O-Matic."
Agree with Dave H on the friction disks.
Take a look at the TOUCH-O-MATIC QUADRANT ASSEMBLY Standard diagram below.
Note the friction disks (Key 21).
Hope this helps.
DoubleO7
02-14-2018 06:45:05
it is a 420S, maybe why it only has the single lever.
DoubleO7
02-14-2018 06:42:55
Yes, only one lever for the 3 point.
Has five speed but not the optional live pto, just tranny pto.
I have not had it a year yet and just started using the chipper.
I will check out the friction disc, thanks.
P.S. can chip hard green limbs in the 5" dia. range. Gives the 420 a good workout, Sometimes you have to play with the chipper feed handle to catch it in time before it stalls out.
Dave H
02-14-2018 04:57:30
Doesn't your book show friction disks for that assembly?
I had to replace mine.
However, mine like most i have seen was a dual TOM.
mr.precision
02-14-2018 04:53:24
You wrote " single touchomatic".....so you have only one lever for the 3 point? Didn't know the 420 came in that configuration. If you have 2 levers, I can help with your concern.
Mike M
02-14-2018 04:50:30
If the lever is moving then I think there would be a friction spot you can adjust it tighter.
