John Deere 520 three point hitch creeps
MSmith0309
New User
I?ve got a John Deere 520 that the 3 point hitch won?t stay up on, any
weight at all and it bounces from creeping down and lifting up again.
Is there a check valve that can be replaced or anyway to get it to hold
and not creep and bounce? Thanks in advance.
-Mike
Does it also drop down on it's own if the engine is shut off ? First thing I'd suspect is the cylinder o-ring.
PJH is on the right track when he said piston O ring leaking.
They call this hunting when the 3 point constantly is jerking up
then settling down. I had this same thing on my 520 years
back and the fix wasn't terribly hard. Good luck
JD has a VERY nice service manual just on those units. I highly recommend it. Trouble shooting charts in it too. Sorry I do not have the manual number handy.
The JD Service Manual for Custom Power Trol is SM 2022 and the section covering
the piston and cylinder is 60- 25- 1 This manual has wonderful detail and makes
the job much easier. Good luck.
I've never had any problems with my JD 520.....however here are a couple of pics:
Parts Catalog PC-527-(May -66)
Bob....
