TractorLinks.com
Show Parts for Model:
John Deere 520 three point hitch creeps
msmith0309
02-12-2018 18:27:25
Iíve got a John Deere 520 that the 3 point hitch wonít stay up on, any weight at all and it bounces from creeping down and lifting up again. Is there a check valve that can be replaced or anyway to get it to hold and not creep and bounce? Thanks in advance.
-Mike
John Deere D
02-13-2018 15:37:01
 Re: John Deere 520 three point hitch creeps in reply to msmith0309, 02-12-2018 18:27:25
I've never had any problems with my JD 520.....however here are a couple of pics:
Parts Catalog PC-527-(May -66)
Bob....
Mike M
02-13-2018 07:53:27
Does it also drop down on it's own if the engine is shut off ? First thing I'd suspect is the cylinder o-ring.
msmith0309
02-13-2018 08:14:22
 Re: John Deere 520 three point hitch creeps in reply to Mike M, 02-13-2018 07:53:27
Yes it drops down when itís off, Iíve never taken apart a powertrol but looks like I will be.
Mike M
02-13-2018 12:11:19
 Re: John Deere 520 three point hitch creeps in reply to msmith0309, 02-13-2018 08:14:22
JD has a VERY nice service manual just on those units. I highly recommend it. Trouble shooting charts in it too. Sorry I do not have the manual number handy.
machineryman1945
02-13-2018 04:01:15
meant to say draft control
machineryman1945
02-13-2018 03:53:13
Sounds like something connected to the dept control valve.....look in manual may be something as easy as an adjustment....
PJH
02-12-2018 18:58:00
I would suspect the rockshaft cylinder o-ring. Let us know what you discover.
Larry Davis
02-13-2018 07:56:14
 Re: John Deere 520 three point hitch creeps in reply to PJH, 02-12-2018 18:58:00
PJH is on the right track when he said piston O ring leaking.
They call this hunting when the 3 point constantly is jerking up
then settling down. I had this same thing on my 520 years back and the fix wasn't terribly hard. Good luck
Larry Davis
02-13-2018 12:58:34
 Re: John Deere 520 three point hitch creeps in reply to Larry Davis, 02-13-2018 07:56:14
The JD Service Manual for Custom Power Trol is SM 2022 and the section covering
the piston and cylinder is 60- 25- 1 This manual has wonderful detail and makes
the job much easier. Good luck.
