3020 oil leak
We have a 3020 diesel leaking engine oil. It's leaking at the #4 exhaust port. Coming out between the exhaust manifold and the head. No visible oil smoke from exhaust. Could this be a exhaust valve stem seal problem? Any ideas would be appreciated.
I agree with Roger,,maybe even a weak injector,,if you could check each exhaust runner with a heat detector you would probably find that one is cooler..
