TractorLinks.com
Show Parts for Model:
Part number 4020 fuel sending unit.
tomstractorsandtoys
02-09-2018 10:39:07
I have a 4020 in the shop that was changed to 12 volt and would like to get the fuel guage working. I ordered a new guage that is 12 volt neg. ground from my parts supplier. What part number sender for in the tank do I need? My parts aftermarket parts place does not carry them. Tom
D-
02-10-2018 10:20:24
 Re: Part number 4020 fuel sending unit. in reply to tomstractorsandtoys, 02-09-2018 10:39:07
I've never had to change the sender when converting unless it was bad.
Tim S
02-10-2018 11:31:37
 Re: Part number 4020 fuel sending unit. in reply to D-, 02-10-2018 10:20:24
Yes the senders are the same,,but over time ,,sloshing back and forth on rough ground wears them out..
tomstractorsandtoys
02-10-2018 09:31:50
Thanks for the replies. I am very electrically challenged. I hate wiring. I had to work on a 24 volt last week and just fixing the lights made me want to burn it. Tom
Ragnarok
02-10-2018 07:41:13
Seems like the last time I installed a 4020 12V conversion kit from JD..the destructions had some part number recommendations for fuel guage and senders if the originals did not work.
I had to swap both parts and also ground the tank sender to get the system to work.
Tx Jim
02-10-2018 06:08:49
1st numbers I posted were for fuel gauge. I don't know what I was thinking about?????
Tx Jim
02-10-2018 04:07:44
Here's the fuel sender that Tim recommends for 12 volt conversion. AR26434
Tx Jim
02-09-2018 13:02:43
Either of these gauges from JD should work for 12 volt negative ground. AR45436 or R160776
SVcummins
02-09-2018 11:11:03
I thought the gauges are 12 volt already
Lee B
02-09-2018 12:13:59
 Re: Part number 4020 fuel sending unit. in reply to SVcummins, 02-09-2018 11:11:03
They are but positive and negative ground do make a difference in the gauge used. Sender doesn't care which ground system it is so same one you have should work fine provided it works.
However early used 10 ohm GM type and later used 300 ohm type. Will certainly make a difference if gauge ordered is for the wrong type. Part number might help.
tomstractorsandtoys
02-09-2018 14:36:35
 Re: Part number 4020 fuel sending unit. in reply to Lee B, 02-09-2018 12:13:59
Thanks that is what I wanted. I wasn't sure if it mattered to the sender or not. I did see the different senders listed and the difference between the early and late ones. Tom
