mr.precision
Bit by bit fixing up this little jewel I picked up locally. My IT Manual isn't much use in learning how the dual TOM works. I will using this to brush hog 12 acres with a 5' rotary mower when the light restoration is complete.
For simple up-down operation, is the lever under the seat supposed to face forward or backward?
Does one need to use both levers to raise and lower the implement? Or just the outer lever?
Should the left 2 lift arms be pinned together?
I know this is basic stuff, but the info on the web is contradictory and I'l like to have someone that uses the 3 point lift to give me a few pointers.
Thanks
Thanks
