Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Is this a 3020 or 3010
chas036
02-08-2018 07:48:11
Can someone tell what model this is , 3010 or 3020 ?
chas036
02-09-2018 06:46:00
 Re: Is this a 3020 or 3010 in reply to chas036, 02-08-2018 07:48:11
It is a gas tractor and it is at an auction that will take place on 2/20. I think since it is a 3010, I am going stay away from it.
Tim S
02-09-2018 07:30:35
 Re: Is this a 3020 or 3010 in reply to chas036, 02-09-2018 06:46:00
I'm with Mike,,stay away from it...there will be a couple people there that will not know the issues that come with a 3010 gas, and most likely they will make it bring more than it's worth..just my thoughts...
Mike M
02-09-2018 07:15:27
I'd stay more away from it since it is an auction tractor more so than it being a 3010. I would not have a problem buying a 3010 or 4010 from an individual in my local area that has a good reputation for taking care of their machinery. Plus you can actually take them for a test run and even work them beforehand.
Mike M
02-08-2018 11:35:54
That's a diesel isn't it ? Hard to tell on my computer. If it is that will make several on here happy for you if you buy it !
JIM MN
02-08-2018 11:30:53
Look at rear pto; is the stub shaft bolted on with four cap-screws? If yes; a 3010......
chas036
02-08-2018 09:36:52
By much improved PTO, in what way? Since the only pto work I would use this for is bush hogging or a small manure spreader, then would the improved 3020 pto really make that big a difference for what I want to do?
Tim S
02-08-2018 08:09:38
It's a 3010 the PTO lever is on the right side..
Tim S
02-08-2018 08:11:19
 Re: Is this a 3020 or 3010 in reply to Tim S, 02-08-2018 08:09:38
OOps I don't know my right from my left today,, I meant the PTO lever is on the "Left" side,,,Darn it...
D-
02-08-2018 14:08:35
 Re: Is this a 3020 or 3010 in reply to Tim S, 02-08-2018 08:11:19
It's not your fault. He should have taken the picture from the other end!
Roger in Iowa
02-08-2018 08:32:02
My 3020 pto lever is on the left side, but it is also a right console hydraulic lever model.
What other distinctions are there between a 3010 and a 3020?
DR. EVIL
02-09-2018 10:06:54
 Re: Is this a 3020 or 3010 in reply to Roger in Iowa, 02-08-2018 08:32:02
No diff lock on a 3010, only available on 3020's.
If you plan on plowing with the tractor the diff lock Really helps traction, I used diff lock a LOT when plowing. Really missed it on Dad's 4010.
chas036
02-08-2018 08:23:15
How much difference between a 3010 and 3020? Can you convert a 3010 to a 3020 by changing the sleeves and pistons like you can with a 4010 to 4020?
ET
02-08-2018 11:18:32
 Re: Is this a 3020 or 3010 in reply to chas036, 02-08-2018 08:23:15
The system that shifts the pto from 540 to 1000 rpm can be a problem on a 3010. If you know what to look for and keep track of it I don't see it as a problem. Is that gas or diesel?
long green line man
02-08-2018 09:13:30
If its been overhauled in resent yrs. it a very good chance it already has 270ci. 3020 motor, Major diff. is pto system , Much improved in 3020...
Tim S
02-08-2018 08:58:04
yes you can change the bore,,but that is not the main difference
