John Deere Tracks
The pitch is the same, but the bushing diameter is larger and you will either need very worn sprockets or the sprockets from a 420/430. Many long years ago, Deere had a program to replace the two bolt pad tracks on 1010s with the new 4 bolt type and there were lots of sets of two bolt tracks around. I picked up a set and ran them on a 40C. The sprockets were worn enough that the bushings fit. Not the right way, but it worked and I ran the machine for 25 years that way.
CPeter
