i have a 4455 in my shop that i had to do a complete tear down rebuild the traction clutch input planetary and out put planetary. and pto clutch clean valve controls ., this all do to contaminated hys fluid did the brakes last spring.. my question this tractor was a clean machine.. i had to remove duals hubs spread wheels split at engine remove the clutch housing and three point hitch oh and cab.. in process of pouting back together i never done a power shift before have done lot quad range .. i was wonder about how many man hrs it should take i know how many hrs i have ob the job but was wondering if i am in the ball park. keep in mind it had do lot clean out replaced all the clutch plates piston sealing rings .
