1929 JD "D" correct fuel lines and routing
bmklawt
Need help getting the correct fuel line routing for a 1929 D, I had an older gas tank on my tractor when I bought it. I know have the correct tank and would like to plumb this up as was original. I snagged this picture from eBay, is any of this correct also should there be a gland on the end of the water feed pipe into the block or packing. If anyone has a picture of what it should like I would be much appreciative.
Bruce
Can't help you with the fuel line routing. I have a 27 and I think that's different than a 29 but, the fitting that goes into the block for your water valve is just a packing.
