Tires on a 5020
I have just recently bought a JD 5020 and wanting to put some 30.5x32 tires on the rear. What size rims should I use and where can I get them? I bought the one that was for sale on Ebay that was taken apart and now I have to put it back together but want to go back with the float tires. Its going to be nice. Thanks in advance.
You can find this information in a tire catalog, and according to the online Titan tire catalog, the 30.5 x 32 tire requires a 27 inch wide rim. The following link should take you to the page where I looked this information up. I believe all you will have to do is copy and paste this into your browser.
http://www.titanstore.com/info/48D196
(quoted from post at 21:31:25 02/02/18) 2002silverado thanks for the website. FDT860 how do you widen a rim?
Either find a couple more 32" rims and cut what you need out of them, then cut your rims and weld it back in. bevel the edges and go in about 5" passes till you have them all welded up, grind smooth....or cut your rim, get you some 14 gauge and a roller...then repeat the above steps..
